How To Remove High Level Brake Light
I want to check the washer is connected correctly and look at the seal, then disconnect and dry the high level brake level light out as water inside. I noted there are two grommets (mine were missing) but got 2 from a Fiesta. Removing the grommets do I just push through the hole with a screw driver to release each side, and does it clip and push back in easily.
Don't want to begin without being sure...you know what happens, it won't go back in and you drive around at xmas with it blowing in the wind!
Flat bladed screwdriver in hole, there is a metal clip that needs pushing to one side to let lamp out, so use screwdriver as a lever
Great, thanks Ian. Does it clip back in easily?
Yes, just pushes back in
Great, thanks again for taking the time to reply!
