Please Help
I have purches a voltage meter can someone please tell me where I can wire this into as I can't use my lighter as it always on an I don't want to much running when ignition is off
What voltage do you want to read?
Well it is to read how my battery is doing so I want it to read off the battery so I think 12v thanks
Do you want to monitor the battery voltage?
You could just connect an OBD device or go into the Instrument cluster menu to display the electronic displays. I'e exact revs etc
If you want to wire in the voltage monitor, just splice into the cigarette lighter feed. Or if you only want to see the voltage when the ignition is on, go into the spare ignition switched fuses in the fuse box
Hi yes just the battery voltage and can't use the lighter as the lighter is on when ignition is off and I only want it to come on when the ignition is on where shell I connect it thanks
Look in your fuse box & find an empty socket. Connect the voltage meter & earth it to a bolt above the fuse box.
Probe each fuse and find one which comes on when the ignition is on
Alternatively, use a multimeter to find a switched feed
Or, go into the switched radio feed
www.yorkshiredetailing.co.uk - approved resellers of the Highest quality Detailing & Valeting supplies
If I connect it to the fuse box will I need to add a fuse and could I connect the live to the red lead on radio and the black leads to a earth somewhere thanks
The radio doesn't just have Red & black
If you wire to red and black you'll have a constant feed. The yellow is switched I believe. There should be a blue 12v+ on the radio too
I will have a look at the radio manual as it's after market thanks
If it's aftermarket then use the blue wire as + and black as -
So shell I splice the wires and it it pure blue as I no there is a blue and white also thanks
There should be a blue wire labelled for amp remote. Use that as your + & use the black as your -
Oh I see I have a push button to that for my amp would it still work or can I use the switched wire to stereo and black thanks
It says I have continuous power supply is yellow switched power supply is red and ground is black thanks
Yellow should be switched yes
It says red is switched on mine yellow is continuous thanks
The two can be reversed dependant on the car. It's always one of the two so whatever works
Oh I see it is yellow sorry thanks so can I wire this to the switched and to the black ground thanks
Yes. Use whichever wire is switched as the + & the black as -
Thanks for that pal
