Spray Paint On Windows
So whilst spray painting some scratches on my car I got small specks of spray paint on my window anyone recommend something to get this off?
Gentle abrasion with fine wire wool will do the trick :)
Or use a little white spirit & avoid contact with rubber trim etc
Cheers mate steel wool did the trick
t-cut. also nail varnish remover but be so careful with that stuff on your paintwork. best to soak in a paper towel and squeeze it till you get no drippers. also try the rubber part of your ice scraper. white distilled vinegar is also good for your glass on your car too. wet a paper towel with the vinegar and apply to your windows on the outside in the cold winter months. it stop water droplets from forming ice crystals.
T cut is the work of the devil!!
There's no need for all this aggressive stuff! Buy a clay bar. After all. Surface contaminants are what they're designed for :)
Clay bars will remove pollen, tree sap, overspray, paint transfer from an accident if you're lucky :) and tonnes of other contaminants
Run your hand over your paintwork when its "clean"
If it isn't smooth to the touch, buy a clay bar!
