Upgrading From Bluetooth To Bluetooth With Usb And Music
Hi All
I originally started questions about doing this upgrade in another thread (1.6 TDCI)but I should of started a new one as it is now specific to this upgrade.
I have a 2010 fiesta Sportvan built 30/9/2010 with bluetooth module 8M5T 19G488-AR
It has the Bluetooth stalk factory fitted
I want to upgrade to the Bluetooth with USB and music
I have bought from eBay module 8M5T-19C112-AS apparently from a fiesta (80.00)
I have bought from ford trim cover finis 1572824 (4.07)
Finis 1715190 Control ( this looks like the bit that goes inside the trim and houses the USB port) (5.49)
Wire assembly finis 1755525 I do think that this lead is correct as it has the USB connector on it along with loads of other connectors. (48.84)
The ford parts man also thinks I need this lead so I also purchased it but I am not so sure I do and welcome any advice on this as I don't want to spend ages trying to find somewhere to fit it! Wire assembly Finis 1715190 (33.08)
I think I now have all the parts I need so any help in how to fit them all would be great.
I'm aware I then need to go to Ford for IDS.
cheers Vin
Anyone ?
Anyone?
I'm not sure of the part numbers as I'm just an auto Sparky and don't work for ford. But I think you need the loom that runs between the headunit and the Bluetooth module, but if you go to a good ford dealer with a semi competent parts bloke he can check all of this out for you.
I've recently gone through a similar upgrade- If I remember, I'll try and update you at Lunch.
Hi Ford
any chance of the update?
cheers Vin
