Blue Smoke After Oil Change
Hi
Question,
why would my 1.4 TDCI have blue smoke from the exhaust after an oil and filter change?
Ive checked dipstick ( im questioning the dipstick as it has a twist/kink in it) and level is just below the max line, and i used the correct 5w30 oil.
Engine runs just fine after the change but i have no blue smoke before it.
Any help?
thanks
Joe
Blue smoke from the exhaust is a sign that somewhere you're burning oil - keep an eye on the level and see how much it consumes
Edit: Idea - I know you say the level is just below the max but perhaps you put a little too much in and it's being chucked out through the crankcase breather into the turbo and cylinders?
Hi Chemfusion,
Yes this may be possible and I will be keeping a very close eye on the level.
If it is being blown through the turbo etc how can I clean it out..... That's if it's possible to?
Follow up.....
it seams to now just emits a biggish  puff of blue smoke on start up from cold........
Possibly oil seeping past the piston rings / worn piston rings
Was it blowing any blue smoke before you did the oil change? What is the oil level like on the dipstick? You might have overfilled it slightly - if you pull off the take hose that connects onto the turbo and see how oily it is as that is where the crankcase breather chucks the oil vapour.
