Fusion 1.4tdi (2004) Steering & Suspension Settings
I am looking for the values/angles and  tolerances of camber, caster and tracking.
Whilst the camber angle is not adjustable due to the way the bottom of the strut is fixed (unlike the Fiestas)  I wish to check it following a nudge by the nearside front wheel on a stone recently.
My local repairer says the camber angle is 1/2 deg out but not said whether it is a positive or negative error. I am very familiar with the Fusion front end having replaced the suspension on both sides and doing the two Ford mods at the same time and think I should check and confirm, or otherwise, the stated error.
Thanks in advance.
David G (F66)
Do you want figures in decimal degrees or degrees and minutes?
Thanks Ian.
Decimal degrees will be fine. Ta muchly.
Regards,
David G (F66)
Caster +3.72 degrees, tolerence +4.72 to +2.72
Camber -1.05 degrees, tolerence +0.20 to -2.30
tracking toe in 0.50 degrees +/- 0.34 ( 3.3mm toe in +/- 2.3mm)
Ian ... Many thanks...much appreciated.
David G (F66)
May I ask what the 2 ford mods are please ?
These are 2 zinc rings and 2 rubber rings which fit below the front coil springs. The idea is to reduce spring failures.
Check the online parts catalogue at eucatparts.com There is a mod sheet there. Parts can be had direct from Ford.
I suggest you see my earlier postings on this subject.
Hope this helps!
Regards,
David G (F66)
