Oil on pipe
Hi
I found this cable or pipe there is a oil or what it is
Were am i looking, is it the piece where the wires are coming off the cables wrapped in insulation tape, if so put flash on then take a picture from underneath if possible, then a picture of sump area
The sump is leaking yes Im going to change it next week Will try take a picture from bottom but how does it look like the leak is from where? And yes the wire or oipe is covered woth tape
check this sump leaking
Looks like you need a new sump plug and new washer fitting, I'd look into seeing if the gasket is OK on the sump if not change that as well for a new one, if OK get the bolts torqued up to correct pressure, as to me that's were the oil is likely to be coming from, sort that lot out, then do your best to clean the oil from the cable in your 1st post. Hope this helps
Yes I am going to ford next week to change whole sump as its leaking ! And about that wire you think its from the sump? But this wire is further up sump is at the bottom
