Drive Belts - Help Please.........!!!!
I own a 2008 Ford Fiesta Mk6 1.4tdci and need to replace the steering pump drive belt.
However, when I try to find the part I require all websites show mine has being fitted with one drive belt that drives the alternator, A/C and steering pump etc..
My vehicle is fitted with TWO (2) separate belts - one drives the hydraulic steering pump and other drives the ancillary items etc..
Has anyone had similar issues and maybe know the part numbers for these items?
Since posting I have found someone who had a similar issue and has advised that a normal auxiliary drive belt can be rerouted and used in place of the two belt set up.
Edited by chris301up
Help found
Contact IanTT here on the forum
www.yorkshiredetailing.co.uk - approved resellers of the Highest quality Detailing & Valeting supplies
The Gates catalogue also only lists one belt, their part number is 6PK1708 and this drives the ancillaries as well as the power steering pump.
The ContiTech catalogue has the same their part number is 6PK1705
