Removing interior reading / courtesy light console Focus 2010/2011
I have Ford Focus titanium 2010; reading light bulb in the front overhead keeps going off and need to move it around or push to bring it on again, seems loose contact. I cannot fix this just by removing the cover and wish to remove entire console/casing, but don't know from where and how to do it.
I will appreciate some experienced suggestions and advice.
Naresh
There is a notch where you insert a screwdriver, this is the same notch that you would use to remove the plastic cover. There is a metal clip that you press a small flat blade screw driver against and the gently prise the whole unit out. You can then access the bulb holders from behind the unit. See the pics below.
Insert screwdriver and press in metal clip:
af9e00d8-1789-4336-985f-94f7eddccbe2_zps
Showing the metal retaining clip:
ee6813e8-fed8-4f83-9f9b-f43510380be9_zps
