Buying used alloys help
I'm looking to upgrade to some 17 inch alloys for my zetec s. I know the pcd is 4x108 and believe the offset is 47 for fiestas. My question is will any 4x108 fitment alloy do or do you have to have a similar offset and tyre sizes on etc.
I've found some alloys that are the same pcd they came from a Peugeot and he doesn't know the offset so I'm not sure if they'd be right for the car in case the offset was too far off
IIRC Pug Alloys would stick out, where as Fez alloys would fit a Pug with Spacers.
The 206 for example has an offset 20-34
Peugeot offset used to much less (ET18 on the 306 gti wheels), always needed spacers to fit Ford wheels to Peugeots.
The offset should stamped inside the wheel btw!
Would a offset of 38 be OK for a fiesta?
Well they'll stick out 9mm more than the ET47 ones, so depends if your arches are wide enough to take that?
Will 215/45 r17 off a pug fit my mk6 fiesta??
