Mk7 fiesta zetec s boot light not working
My boot light won't come on changed bulb. With no look please help
Hi & welcome :cool:
Wrong section
Hello and Welcome Tony:smile:
Have you checked you new bulb actually works, it is possible you've bought a new dud?
If it's the only lamp in the boot won't illuminate. Have you checked the door switch and the lamp socket?  Check the earth connections to the car?
If none of your interior lamps illuminate, check the fuse in the passenger footwell fuse box.
Are you sure that you put it in properly, quite hard if you don't look? :laugh:
Is it a standard bulb or LED? (Some LED's have to be fitted in one specific way)
I had the same problem in mine.
Does your interior map light work?
The interior lighting, footwell lights and boot light is all on the same circuit.
I replaced the map light unit for £20 and all of the lighting worked again!
If you can, use a multimeter to find the break in the circuit and go from there..
