Wont Start -- 2009 1.6 zetec tdci
Hi all,
I have a 2009 fusion 1.6  Zetec tdci which after a short trip to the shops (less than a mile) parked up at home but noticed that the radiator fan was still running, this went on for 30 mins or so until I decided to unplug it from its loom. Came back a few minutes later re-attached the fan which started spinning straight away and tried to start her up, she cranked over a couple of times slowly as if the battery was drained but failed to start.
Left it again for a few minutes and tried again, this time turned the ignition on, all lights showing normal but she wouldn't turn over, turned the key again and got the same, dash lights come on no clicking sound as there normally is. just nothing. Battery is showing as having 12 volts, all fuses behind the glove compartment checked and they were fine, connected it up to a charger/jumper unit and nothing.
Any ideas?
Thanks in advance
get a diagnostic pluged in sounds like a immo problem or ecu fault.
still sounds like battery gone flat, the fan staying on is quite common, its the fan relay that has stuck on, its in the relay box next to battery, plug fan back in and then tap each relay until the fan stops, thats then the relay to replace.
As said above
It's the relay sticking I'm the box.next to that battery.
Had the same problem on my 2009 tdci
It would have drained the battery without doubt as 12v will struggle to turn over... Need nearer 13v..
I pulled the relay and opened it up and cleaned with electrical contact cleaner
..been fine since.
There is only 4 relays iirc.
Think it was the grey, pretty easy to trace the wires from fan to which relay
