Help
We bought a Ford Fusion, reverse light wasn't working so we changed the bulb and it still doesn't work we didn't get the owners manual so trying to find the fuse is almost impossible and we can't find nothing online. Some one help me please it's a fusion 2 54 plate and a 1.4 petrol
Try putting your reg Into www.etis.ford.com. should be able to get the owners manual from there.
Got the same problem with my 1.6 petrol.I tried replacing the bulb,the holder still nothing
try fuse 48.
If the fuse is ok, then it could be your reversing light switch (broken)  which is located on the gear box.
I also had this problem turned out to be a snapped cable coming from the reversing switch worth a look
