Dash Boot Release Button
Hi. I've just bought a Fusion and I love it! 2 things wrong however: the boot release dash button doesn't work, but the remote keys work fine. Any ideas how to fix it? Cheers.
  • 1 month later...
2 possible things,
button is broken or wiring issues
  • 1 month later...
If it works on the remote, then the wiring, servo and central locking GEM part is fine. The button connects to the GEM module and appears to feed a ground signal to the GEM so no live feed to the switch. Pull the button out and with a bit of fine wire jump the two pins in the connector and if that works then it's the button. If it doesn't try jumping from a good ground point to the yellow striped wire as that is the feed to GEM. If that works then the other black wire has a broken connection to ground. You can replace it by a new wire from a good ground into the connector to the switch.
