Constant Cooling Fan
My 2004 Fusion 1.4 16v is running with the cooling fan constantly on.
Any idea's what could be the cause?
Your help would be appreciated.
Even with ign off?
No, ignition off and all fine
Only when engine running, all levels are fine.
Have you got aircon?
Yes
Make sure aircon is off and check fan, if ts still on then most likely is coolant temp sensor or wiring to it is open circuit,
Will do, thanks for your help...
