Solid Flywheel Replacement For Original Dual Mass Version
S Max Zetec 2007  TDCI 1.8
Looks as if I am having to fit a new flywheel and see that you can buy a solid conversion kit to replace the original Ford Dual Mass version.
Anyone any thoughts?
Regards
How many miles on your car Paul? I'd advise do NOT get the kit. I've read on other forums on other cars that soon after fitting a kit that vibrations occur and in some cases the crank snaps because of the massive imbalance.
Probably the flywheel doesn't need replacing but just the plates.
The DMF is fitted to save breaking things (transmission & crank mainly), yes new new ones are expensive and eventually go wrong but I'd stick with the DMF unless you're modding for big power personally.
The car has done 115k.
I have now decided to stick with the original Dual Mass flywheel since I have read the argument elsewhere, that the engine, transmission and gearbox have been designed in conjunction with the DMF and therefore making a change puts the other components at risk. Sounds like a sound argument.
