Jerky throttle response
Got a 07 Fusion Duratec recently while driving noticed a jerky throttle response.
This only happens when the speedometer is not working.
Has any one come across a similar issue.
How to resolve this.
  • 3 months later...
Hi newbie yes I have had this problem in the past changed spark plugs then ok.  Also found I had same characteristics took to a specialist garage for electronic and ecu problems in Warringtod they diagnosed coil pack problem they fitted a new Ford coil pack and ht leads wow it was suddenly like a ford Ferrari.  Hope this helps.
  Regards jim
Jerky throttle on its own could be plugs & coil pack, as Jim found, or dodgy throttle body.
But if it really is linked to the speedo failing, then it looks to be more of an electronic problem. Likely suspects are the IC (Instrument cluster) & the wiring to it.
The IC gets speed data from the ABS (or PCM if it is a non-ABS car), and usually it reads one of the dual accelerator pedal sensors, and sends this data to the pcm. The main system bus (HS-CAN) carries this data.
If it is electronic, I would be a bit surprised if no codes (DTCs) were being generated. A system like Forscan can read all the car's modules, and extract any DTCs. These might give a clue, if found.
