MK7 Headlight removal
As above, I cocked up changing the numberplate bulbs, a costly error, so want to get some advice before I tackle removing the front headlights
Did a quick search, which kept returning 4 pages with any post containing the word headlight
Alex
Anyone?
These are 2 links I have been mailed, just incase anybody else needs a hand on removing the lights
Headlight removal in pictures
Thanks to tyrefryer for his guide
as for the front lights they took me a while to workout how to do ,firstly undo the screws like it says in the manuel there are 2 screws ,the other is like a plastic cap thing at the front of the light on the corner use a flat head screwdriver to lift this one out.
then disconnect the wire plug.
once all screws are removed there is a white clip underneath the light ,this is the part i found akward , if you shine a torch on it you will see how its holding the light in ,its basically just a mount type clip. all i did was lift the light slightly and move the clip with my hands any way i could until it came free.
you may find it better if you had someone help you do this as i had my dad lift the light a little while i tryed to free it from the clip.
it took a while but once you do one light you will see how it works
Thanks to mitch84 for the guide
  • 14 years later...
