Ford C Max Brake Light Fault
My Ford C Max driver side brake light bulb keeps going out even though I have replaced it with a new bulb, as recommended in the manual.  Any help to correct this would be greatly appreciated.  Thanks
Have you checked the old bulb(s) to see if they have gone? If the bulb is ok, it must be the switch or wiring, or a bad connection, possibly in the light fitting.
swap it over to passenger side to se if it works there it not bulb holder could be faulty just athought
