New to this
Hey ppl new to this just recently purchased a 2010 focus zetec s 1.8 petrol and was hoping someone would be able to point me in the right direction to after market parts looked all over for a bonnet with grills and rear spoiler to no availe...pls help need to make my car more sexy on the eye
The Zetec S spoiler is already exactly the same as the ST one so maybe an LED upper brake light?
Buy the bonnet vents and fit yourself, a steady hand and an accurare tape measure is essential.
Sent from my SM-G930F
2010 model should have a clear smoked led brake light in the spoiler from factory👌
+1 very steady hand indeed meassure twice cut once
you may like to view my guides here:
And build thread here:
IMG_20150521_170322_zpsdmdonn7m_edit_145
IMG_20140906_152452_zps1jkypxk_edit_1414
Thanx ppl really appreciate the comments and will defo look for what you have said also looking to lower all round at 30 ml  and get a green induction filter kit as shown by Lenny but seen before I joined here just don't no if it will do my car if so would it increase power and does it make a waste haste noise???ie dump valve as the lil one loves that ha???
lowering the car definitly improves handling and fuel economy, however it does also require laser tracking alignment done after the springs have been fitted to correctly align the camber otherwise you will end up with excessive tyre wear.
The Tracking alignment isint difficult to have done but definitely worth factoring in to the overall price of lowering the car, costs around 50-70 pounds for tracking
Upgrading the induction filter will give your engine a bit more of a throaty grunt but not much increase in power because your engine is naturally aspirated it's not creating as much vacuum as turbo
Dump valves are fitted to petrol turbos to vent off excess boost pressure when the clutch pedal is pressed, the venting prevents blow back which gives a flutter sound but causes cavitation within the compression housing of the turbo which weakens it's structure.
The dump valve prolongs turbo life.
you can however; fit a saber electronic dump valve which gives off the impression your running alot of boost even if your on a bicycle
Hahaaaa love that Lenny il get one for the Mrs bike..so to make a it of noise (not tinny) and a bit of noise whisp what would u yourself recommend???(my car is nearly the same look as yours but blue with 18's snowflakes
TeTracking alignment isint difficult to have done but definitely worth factoring in to the overall price of lowering the car, costs around 50-70 pounds for tracking
Dump valves are fitted to petrol turbos to vent off access boost pressure when the clutch pedal is pressed, the venting prevents blow back which causes cavitation within the compression housing of the turbo which weakens it's structure.
Can this be heard outside the car?
Yep
it's two speakers fitted inside the engine bay or behind the front grill
Oh that's a lil to fibbing for me,I thort their was a way to make a sound without a turbo you no of any except that one maybe a filter or intake?
Only other thing is this
Or ultimately and my favourite these 😀
Oh that looked terrible not for me...
Oh dear lol guess it's just an exaust for me then sometimes I wish I still had me evo none of this palarva
I've given up on cars and performance myself, I've moved on to doing up the house, most powerful thing i have now is an 80W led flood light 😀
turns out 80W led light is equivalent to 1200w Halogen 😂
back gardens like a stadium 6000kelvin even the moths be like😣 "Damn Lenny that's bright"
