Lowering on standard shock absorbers
I was just wondering as I want to upgrade the suspension on my Zetec s mk6 but don't want to spend a lot of money so was just wondering what is the maximum drop you can put on factory shocks was thinking of lowering 40mm btw
40 mm on a standard setup sounds much. What are your current measurements and you also need to factor in the legal aspect :).
My MK3 focus had 370 mm rear and 350 mm front on stock. Imagine being able to reduce that by 40 mm from factory. Maximum I believe should be in the 15 mm ballpark on stock.
If I were to run napkin math according to the 40 mm you want I would have :
Rear : 330
Front : 310
Front will not pass the road viability check.
Rear : 330
Front : 310
It wouldn't be a problem here legally.
id look at 30-35mm
