Mk7.5 Headlight Retrofit
Apologies if this has already been discussed somewhere on the forum, just can't find it anywhere.
I have a 2013 Mk7.5/Facelift Ecoboost - Can the revised headlights with built in DRL strip be retrofitted onto my fiesta that uses standard halogen bulb's as a DRL?
I've already seen that the newly revised tail lights can be retrofitted without a problem - Just wanting to know if the headlights are the same!
Thanks in advance,
You have to adapt the connector plug as the two headlight types are wired differently. So no straight swap I'm afraid
Thanks for the reply - Had a feeling it would be a no go without some faffing about.
  • 5 years later...
Can anyone what wiring modifications are required in order to get the lights working correctly?
