Fiesta 1.4 TDCI VIBRATION
Hi all,
I am new to this forum so hi to all and I am hoping I can find an answer to my problem. i have a 1.4 fiesta tdci 05 reg, it's done 164,000 miles without a problem till now. The clutch went about 3 weeks ago, so had a new one fitted and since then I have a vibration that starts in fifth gear engine underload going up hill at around 1800 rpm /50 mph with light throttle it feels like the engine is shaking loose? Had it back to the garage they have looked at many things and couldn't find anything wrong. So after much debate they decided to change the clutch again in case it was a fault on that they checked the flywheel which is perfect, rebuilt it and it's exactly the same. They say there is some end float in the crank shaft which may be causing it?? And have advised I could need a new engine?? The car drives faultlessly in all other gears and conditions and if you accelerate through it it goes? There's no nasty knocks or rattles from the engine it is sweet. Has anyone experienced this before?? Any help greatly appreciated as it's becoming annoying now and hate the thought of an engine change. Thanks in advance.
Dave.
