fiesta mk7 wing replacement
can anybody tell me how i get to the 10mm bolt that is at the top of the wing and looks like its under the small glass. its got me baffled ???
  • 3 months later...
were you able to solve the problem of removing the bolts.
This video is a decent guide! See if it helps.
Get someone to pull gently on the quarter glass, get an open ended 10mm spanner in there and give it a few turns, you don't have to take the bolt completely out, just loosen it. Should come off then.
Hope this helps!
