Tire pressure
Hello Guys,
Im new to these so be gentle :)
I have a Fiesta Zetec S 2014 and it keeps shouting at me to check the tire pressure, i have reset the tire pressure on the console and then it just comes up again 5 mins later, anyone got any ideas, i have checked them and they are all different from each other so i guess it could be that, could anyone tell me what the tire pressure should be for this car?
There should be a plate on the passenger door sill that tells you the correct pressure for your tyre size & load.
Thank you :)
1 hour ago, harleigh95 said:
Thank you :)
In mine is on the passenger side (which is driver side for US LHD vehicles) - I would suggest checking your tyre pressures once a week, you should notice an improvement in handling and fuel economy when they are at the recommended pressures. You can also get some tyre valve caps which give a visual indicator as to the tyre pressure as well, although perhaps not needed on a newer car like yours!
