BATTERY / OIL / SEAT CATCH
Hi everyone, posted this on a separate topic yesterday looking for some advice, got one reply with helpful advice from a other forum member but I've re-posted just to see if i can get it a bit more advice from other ford owners. Went to Halfords last week for one of those free winter car checks. When they tested my Fiesta's battery it gave off a reading off around 250/255A on the multimeter. The battery is in my Fiesta is supposed to give off a 390A (see pic attached), he said it's likely that it could be the same battery that it left the factory with back in 2007, he couldn't really give me a straight answer when i asked whether i should get it replaced or will it last a little longer (not really sure how long car batteries are supposed to last). He said that doing short journeys can harm a cars battery as well, just wondering if this is true or whether it's just a myth. If you think i'm best off getting a new battery asap some recommendations would be appreciated. I've only looked for new batteries on the halfords website, if you know any other retailers that do the same quality but cheaper batteries (including fitting) please let me know. Halfords do seem quite an expensive shop to me, D/S headlamp went out last week and i rushed over to Halfords to get a replacement, luckily they had certain bulbs buy one get one free so i got the bulbs for £25 but came to £37 after paying for them to fit the bulbs (£6 each side). He also said that my oil level is slightly above the maximum level on the dipstick and that having too much can be just as bad as not having enough. Do you think this will end up being a big a problem if i don't do anything about it or should it be ok so long as i keep checking the level?. The last thing i'm desperate to sort out is getting my drivers seat tilt mechanism working again, I've watched vids on youtube of owners carrying out the repairs themselves, it looks easy but knowing the luck I've got i'll probably make it worse. Rang my local ford lookers in Sunderland and couldn't believe how much they quoted for the repair, around £32 for the handle but £75 for the fitting because it takes an hour to do. Obviously until i actually take the handle off i don't know whether it's just the handle or whether it needs a new cable too. So to get it done by them would cost around £100 if it's just the handle or £135 if it needs a cable as well. With Christmas round the corner and me being currently unemployed money is a bit low at the moment. Can anyone tell me where i might be able to get the part/parts cheaper? please + if there's anyone on here that is also living in Sunderland that could carry out the repair for me for a lower cost i'd really appreciate it. Thanks for reading and replies in advance :)
Edited by LIAMSAFC
Forgot to insert picture
I can't answer all your questions but if the battery is the original from 2007 it's likely to be close to the end of it's life. Not sure about the silver calcium batteries but all the lead acid batteries I've been used to  in my previous cars rarely last more than 7 years. Doing lots of short journeys will put an extra load on the battery and if you are doing very short journeys the startups will take more out than the alternator will put back in.
Thanks for the advice mate, think i'll get a new battery pretty soon, i don't travel far tbh so maybe i'm making it worse by not travelling far, thanks again :)
