Fiesta Zetec 2003 Code Reader
Hi there,
Can one of you please advise me which code reader I could get for my Ford Fiesta Zetec 2003.
Too many to choose from on ebay?
not sure if allowed to post links to ebay but is this ok?
http://www.ebay.co.uk/itm/Car-Fault-Code-Reader-MaxiScan-MS309-Engine-Scanner-Diagnostic-OBD2-EOBD-AUTEL-/131865744160?_trksid=p2141725.m3641.l6368
Many thanks
I bought one like that because I had an abs light on and it wouldn't tell me which sensor it was, as far as I can gather the only thing it's good for is clearing codes!
i ended up buying this https://www.ebay.co.uk/itm/132034268924
it plugs into a laptop if you have one, download forscan. It shows you everything in great deal and you can even activate hidden features on your car.
It told me it was the rear abs sensors aswell as historic codes  when the handheld one couldn't even pick up the current faults. I would highly recommend!
*edit*
fixed the link
thanks for your reply Tuffers69.  i ended up buying the one i linked!  hopefully it'll be ok!
i was messing around (trying to fix) with the heater/cold air control as it wasnt working. was just blowing cold.  the sensor came on bout 30 mins into driving,  with the heater on.   hoping its related to the engine light
hoping its a cheap fix!
