traffic cam
i am fitting a next base GW 312 traffic cam to my 2012 focus  i want to fit it through the passenger compartment fuse box (under glove box)with the next base fuse lead but i cant find a switchable fuse. i have tried air con fuse and fog light fuse but the camera is still charging when the ignition is off (power is still there,charging light is still on)
  does any one know which fuse will stop all power getting to the cam when ignition is off
thanks
gav
Which file will I find it in
gav
You'll find it in the fusebox above the passenger footwell.
thanks very much
gav
  • 1 month later...
I have a very similar model camera, and I found somehow that trial and error will work best, just plug it in and keep going along the lines until it only turns on on ignition, that's the best way of doing it to make sure it doesnt drain your battery
