Stripped thread...HELP!
As I tightened the injector clamp bolt on my Fiesta 1.4 tdci the thread stripped out of the head. Can any one help me out with any ideas how I can get out of this mess?? Please.
Assuming you mean the female thread is stripped... It's potentially a tricky repair.  I always hated doing this, especially when the hole was angle sensitive.  It's really tricky to drill in a straight line when you can't put the item on a bench drill!
You can get various compounds which you put in the hole, re-drill it out, re-thread it with a tap, then put your bolt back in.
You can also get some compounds that don't require tapping and all that, but I am not sure about the longevity of these.
Failing these two types of repair being possible, you may need to drill the hole out to a larger size, then put in a thread insert.
Have you got room to helicoil it?
A helicoil is aka a thread insert.
Not necessarily, we fit inserts in some damaged threads and it's not a helicoil lol.
Yes, but where do I get an insert/helicoil? Spent all day yesterday looking
Any local engineering shops, even a motor factors may stock them.
Failing that you could get a kit next day delivery?
Ordered a kit today from Machine Mart, should be here tomorrow. Fingers crossed it works on aluminium!!
