Gearbox gasket
Hi
could someone give me a idea how to change gearbox gasket not the one from outside the one from inside pictures follow I bave opened the gearbox and there are the gears and cannot get to the gasket do the gears needs coming off ??? Or whole gearbox needs to be taken apart??
5th gear synchro assy and 5th gear needs to come off before removing the bolts that hold the plate on. unless you have the correct tool to remove 5th gear then i would reassemble and get garage with the correct tools to do the job
So its quite a big job ? And expenssive for just a little gasket omg that is mental lol
Thanks for reply ! Also I find out the screws where gears are all around were lose so that could be why it was leaking as well I will be keep checking also now the bit where silicone was the first side I used silicone as well hopefully tthat side wont start leak as well
not a big job but a gear extractor is needed, the sychoi assy comes off easy enough but can fall to bits if your not careful. lol
Guess I will leave it as its lol
