Tire size
I need to know if I can use 195/60/15s on my 2013 Fiesta SE Sedan. They have 185/60/15s from the factory. I do see some of the tire websites have 195s as an optional fitment. I assume this is because some of the Fiestas have 195s from the factory. I am pretty sure it is okay, I just want to make sure I will not have any negative issues with clearance or rubbing on the strut when turning. I understand it will be slightly taller. Also, does anyone know how that will effect the MPH?
Thanks for all your help!
You should be okay
Check out this website it will tell you the difference between your tyre sizes as well as tell you if it's safe to do so.
http://www.etyres.co.uk/how-to-change-your-tyre-size/
Disclaimer: Even though the calculations are accurate it's best talking to a professional first.
Will the tyre be taller or wider?
195
That would make it wider then?
