Induction on st150 burning oil?
Recently bought mountune cais for my st150 sounds so nice, but problem is I noticed this morning my oil level is at minimum ? Could it be induction ?? Before I did not notice oil burn etc ??
pfa
The induction kit isn't going to make your car burn oil (not more than its designed to).
It works in the same principle as the factory airbox in that the air/oil that gradually sprays out of the breather into the airbox is sucked back in again and combusted/burnt, but there isn't a vacuum to physically suck the oil out past the cams
When did you last check the oil before now?.. When was it last changed/topped up?
It only lost a little, this dipstick is showing always something different ! I had it changed 3k ago Its showing under line atm on dipstick also was wondering If its in need to change fuel filter on st150?? Its on 74k miles
I mean it took 1/4 oil not sure how as no where are leaks
Check it once the cars been left overnight on level ground everytime, that way you know it should always pretty much be the same
Input your details here for a Service schedule for your car https://www.etis.ford.com/fordservice/serviceScheduleForm.do
Not sure how to check that my car is 56 plate st
Your car is a 16v duratec.. Input your details and it'll tell you everything
Does not work trying to click it does not do anything :(
Works fine for me so it must be you
Maybe because Im using iphone, I got it changed today anyway the fuel filter I cannot believe how improved the response is ! The car is so much smoother
Yeah it was definitely over due then! Haha
I hope you did if yourself? You can actually do it with the car parked up just reach underneath, 30seconds, click click job done :p
Yeah I did just used my friends ramp 👌 So easy but I got petrol all over me lol I shld Of hold the pipe upwards I love how thr car response its unbelievelable
Ah that's good to hear! :)
Must've been well overdue! Yeah I always end up covered in fuel 😂. Supposed to turn it over with the pimp disabled but I've never bothered, only petrol
Yeah I guess it was never changed, I need now keep an eye on the oil level the car could be burning little, but again these dipsticks are nightmate first time it show max next time you check minimum !
