Ford sat nav fitted
Hi after reading this forum I managed to obtain a used Ford Sat nav system that came with everything needed and Inbought the latest Forscan 2. Fitted it all in about 2 hours re programmed everything using the scanner including the dreaded km back to miles and it's working perfectly.
Total cost £265 and I now have a dab radio to sell on with a Bluetooth module that came with the new system.
Im now going to fit the reverse camera as my new screen has the input, a big thank you to those on this forum for their guides.
Well done.
Great job..............
well done
a bigger challenge is to retrofit a genuine ford reverse camera but well worth it as it will do a lot more that just a camera as it has zoom and turning lines . This can be done as I have done sat nav and camera retrofit with no problem just need to take your time. Now you have forscan you can soon enable the camera input.
just found this on ebay not sure if its any good for you but they are retrofitting reverse cameras to fords with original screens.
ebay item number   122485736415
