Induction Kit CAM hose
I installed a K&N induction to my MK5 fiesta and I am running steel pipe round the engine and to the bottom where I will have the filter sitting. The cam cover breather hose won't reach the filter anymore, was wondering if there is a filter you can put on the end of the hose, so the hose doesn't have to go into the filter?
REG: SD08 KTG
Yes indeed! Just google or chuck into eBay the words "breather filter". You need to known the diameter of the pipe spigot so you know which size to buy. Avoid cheap Chinese ones, foam jobs from the like of Pipercross or Ramair provide the best flow and are thus the most affective at relieving crank case pressure. Good luck.
