Ford fiesta day time running lights.
I have a fiesta zetec s 2014 and mine have the standard bulb DTR lights.
I have seen some fiestas with a strip DTR lights, I like these better, will they use the same screw fittings? Thanks.
Highly unlikely....
Screw fittings? If you mean to fix them to the car they are exactly the same, you can swap them they then need programming to work correctly, either by ford (if they'll do it) or someone with a elm lead and the Forscan programme, you can do it yourself with them.
No chance, if you want the LED strip you need to replace the whole headlight unit which is about £270 a go.
If you want nicer DRL, either get a kit from Halford's or replace the H15 bulb with a white LED/white Halogen one, makes it look a little nicer IMO.
My understanding is that yes they are exactly the same fit however the wiring plug is different which would need to be manually wired in, then it would need re programmed by Ford.  As I watson99 said they are not cheap
No, it's just programming that needs doing for them to work.
Yes they are expensive new but, there is more than enough fiestas being broken on eBay that you can pick up a pair used for less than a new one.
