2012 focus n/S/r door control module wiring diagram
Hi has any one got a wiring diagram for a 2012 focus door control module ?  I’ve lost all electrics to n/S/r window and door lock ?. I’ve substituted the dcm but still the same
Thanks Clive I’ve also found this link but the diagram only lists electric windows w/o  DCU see attached link page 67.
My focus has door control units in all doors front and rear and the diagram doesn’t match.
Thanks sam
does show the module driven windows. the page before.
page 65
Thanks Ian, I missed that completely! I checked the wiring on the o/s/r door and found the lin communication line had gone down following the wiring diagram this is generated at the o/s/f door but on inspection the diagram is incorrect, eventually I found the hinge plug assemble in the bottom of the B Pilar was green with corosssion and the lin wire grey and blue had corded out and broken, I replaced  the wiring and all tested ok.  Thanks for your help. Sam
good to hear you sorted it out.
