kledi Posted January 22, 2018 Share Posted January 22, 2018 Someone help me maybe i have a problem with my focus ...at cold car crank normally start but after 4 seconds cutt off and i cant start it try it 5 times already ...just crank and not start.. 😣 Quote Link to comment Share on other sites More sharing options...
isetta Posted January 22, 2018 Share Posted January 22, 2018 could be many many things but fuel filter can clog up on these cars. when was it last changed. if you turn ignition on and leave for a few seconds does engine management light go out as normal or does it stay on 1 Quote Link to comment Share on other sites More sharing options...
kledi Posted January 22, 2018 Author Share Posted January 22, 2018 @isetta all normal i had this problem and i send to diesel mechanic to clean injectors ... clean fuel tank and change fuel filter but .... today it started but cutt off and now wont start .. before cutt of show a message on board engine system foult and die ... Quote Link to comment Share on other sites More sharing options...
isetta Posted January 23, 2018 Share Posted January 23, 2018 hi, you sent me private message, it's probably best if you put it all on here so others can see it. re the fault codes you mentioned, you really need to show all of them here in case someone has had same experience Quote Link to comment Share on other sites More sharing options...
