Headlight mount broken
Had ours done under warranty also, both sides, both now with the correct Ford repair parts.
Body shop also tried telling dealership we had had a "bump" which had caused them to break.... needless to say, this theory lasted a matter of seconds.
15 hours ago, iantt said:
The bonnet is breaking the headlamp brackets, ford know about this and a fix is available without replacing the headlamps.
From this and other threads, there does  seem to be a clear connection between issues with misaligned bonnets (clearance does seem very tight) and broken lamp brackets.
  • 1 year later...
  • 4 years later...
On 2/9/2018 at 12:10 AM, lst said:
Cheers for the suggestions, will give plastic welding a try.
Will do a test run with some other bits of plastic so I can get an idea of the best way to do it.
Your post is going back a while, did you manage to do this yourself? What was your resolution?
I just found the same issue on my daughter's fiesta (2018)
I would order 2276424 right headlight bracket or 2276420 left headlight bracket as required.
3 screws each side of 2244776.
Ford should supply those.  Just checked and they on eBay too.
