mk7.5 brake discs/pads
Hi, currently looking to get some brake discs and pads ordered up, does anyone have the ford parts numbers for a 2013 mk7.5 1.6tdci front discs and pads? (it has rear drums).
i would get something like brembo, i swapped my pads for brembo and the breaking was amazing from the get go iv also got mk7.5 13 plate, theres always a sale on euro car parts or carparts4less same distributor but cheaper
not bad for £54 off
carparts4less is slightly cheaper but they will have to be delivered. where as eurocarparts can be collected from store.
Cheers will maybe give brembo a try, it has two options fro discs on that site, are the tdci brakes the same set up as the ecoboost?
Is it the 258mm OD for the 1.6tdci?
According to Pagid, yes but I encourage you to check using their website.
https://pagid.com/brakebook/
you can go on the website and put in your reg and will bring up the correct parts.
I think that's correct well that's the same size on the mk6 fiestas
I wouldn't consider getting any brake bits from EuroCarParts till you can find a 50% off code. I think they're pretty frequent, I've always been able to find one whenever I've needed discs/pads.
