Mk3.5 dash car picture
You know the little electronic pic of car within speedo area that shows what lights you have on. Doors open etc. Does the car alert you to bulbs being out? or not as clever as that ?
Sent from my SM-G800F using Tapatalk
Not that clever [emoji57]
A pity.
Sent from my SM-G965F (S9+)
Ahh yeah pity.
Thanks anyway.
Yet again Ford are behind the times...Vauxhalls have had bulb failure warnings since the 90s! :sad:
You'd think it would be fairly easy as it senses a current drop. Even if not pinpointing the exact bulb (cough...tyre pressure monitor doesn't either) but just say check ur bulbs.
If it's a canbus system it tells you which lamp is out, and depending on which version of the TPS you have it tells you the pressures and which wheel
Not all of them model and trim dependant, my Truimph 1300 and my Dolomite had bulb warnings in the 70's
I think on my 17 plate titanium it says in manual that it just flags one is low. Certainly only see one reset and no values to be seen.
If it's the basic type which senses of the ABS it does just say low pressure
True but I'd expect a Focus Titanium to have them on Mk2, let alone mk3!
Didn't realise they'd been around on 'normal' cars for that long though, first one I had with warnings was a '98 Vectra B...only issue was it kept saying they were out when they weren't lol.
It should be TPMS on a 17 plate shouldn't it?  Do you have metal tyre valves or normal ones Allan?
Mine are standard dust caps
The TPMS valves can look normal now, not always metal.
It's the actual valves that are different, not the caps.  Though I've confused myself there anyway, the Ford ones aren't metal.  On the valve itself, there is a ridge around it if it's a TPMS one.
Some of the TPMS valves Ford use are metal. My ST has metal ones.
I'll have a look
I give up... :laugh:
I thought the legal requirement was for TPMS on all new cars from 2014 on but didn't even get that right, just checked and I see they allow both DDS and TPMS within that requirement.
I give up... [emoji23]
My valves have a single ridged line around them about 1/3 down but the black plastic caps look like everyday ones.
To add to above this would be typical if I've missed out again. When I bought my previous 14 plate fiesta apparently earlier cars hasd tyre pressure sensors but were moving to new type. Mine was built in the inbetween period and got none lol
Forget the damn cap. :tongue:   Yes that single ridge on the valve is for TPMS sensors so the car should be able to see them individually but may not give you that info on the dash, I don't have sensors so don't know, just DDS on mine.    https://www.ebay.co.uk/itm/Genuine-Ford-Tyre-pressure-control-sensor-TPMS-B-Max-C-Max-mk2-Focus-mk3-Kit-of4/232146217842?hash=item360cfe2b72:g:ilEAAOSwcUBYLXPx
Check your reg on etis and it'll tell you if you should have sensors or not.  It's worth knowing for when you have tyres changed.
ridge on tyre valves means it has sensors inside each wheel . the focus dash doesnt indicate which wheel. but a bit of common sense looking at tyre should indicate which one. lol
Yeah gather this now however as earlier on in thread it looks like a missed opportunity to include that and the bulb failure in the little car graphic.
Would have been cool but not end if the world.
bulb failure should work on stop lamps, low beam and rear fog lamps with a message in cluster.
Oh...that would be good then. Ta
Is it possible to retrofit tpms to a mk3? Obviously with some CCC finagling?
Ah, that's good to know.  So far I've had a sidelight and front fog out lol! :laugh:
It's not worth it if it doesn't show individual wheels.  You can activate DDS with FoCCCus that's almost as good without needing sensors that break when you have tyres changed lol.
