Ford Focus 2006 1.8 Tdci - P0089 - Continuation
Sorry about this, but this is a continuation from http://www.fordownersclub.com/forums/topic/69150-2006-18-tdci-wont-start-code-p0089/
The car still refuses to start, I have done the following.
  • Replaced the filter
  • Used a vacuum hose to pull fuel through from the tank
  • Replaced the Fuel Rail Pressure Sensor
  • Replaced the Fuel Pressure Regulator
  • Replaced the Fuel Metering Valve
There's more below the pic ...
As you can see by the following photo, I have totally bypassed the tank, fuel line and fuel filter by using a funnel and short piece of clear pipe. As I crank the engine the fuel goes down slowly but that car makes no attempt to start.
Here is another pic of the parts I have replaced ...
I did notice that when I replaced the Fuel Rail Pressure Sensor, I started to get a reading when previously it was at 0.
So, what I'm asking now is ... and I don't want to ... do we think all this points to the fuel pump needing replacing?
I have a fuel pump that I collected yesterday after a 4 hour round trip, that is where I got the sensors from, also I got the fuel rail too, is it worth swapping out the fuel rail?
Thanks, Lee.
Solved by RoadkillUK
have you checked the wiring to the fuel rail pressure sensor?
  • Solution
Ok, job done, fixed, sorted.
Turns out that the original problem was the Fuel Rail Pressure Sensor, it was reading 0 at all times, when it should be fluctuating, the reason it wouldn't start after replacing this was air in the system. As you can see by my previous post ^^^ that I used a funnel and piece of pipe to fill the fuel hose, I was actually testing to see if the low pressure pump was sucking.
Anyway, sorted.
Hope this helps someone.
Lee.
