Hello,
I decided for some reason to do a gauge sweep test and an LED test last night, and wanted to clear up a few things.
1. The dash has a red arrowe up LED which I believe is an indicator for when to go up a gear, How do I enable this?
2. The LED test also shows a green speedo diagram, what is this?
Finally; Above the small LCD display that shows mileage and temperature, there is a square that looks like it possibly has more lights/LCD display behind it? Does it? If so - Can I enable this and get it to display anything?
Paul
Various Dash Lights
Started by PaulE, Nov 06 2012 11:36 AM
Ford Focus MK2 Zetec 1.8 Climate Dash lights
5 replies to this topic
#1
Posted 06 November 2012 - 11:36 AM
#2
Posted 06 November 2012 - 11:56 AM
the shift up arrow can be acticvated using the elm cable and ff2 software shown in Preee's guide. not much use though as only comes on at 6500rpm
the speedo shows when the cruise control is activated, will only work with cruise control steering wheel.
#3
Posted 06 November 2012 - 12:21 PM
My red arrow works already as standard.
It just warns you to shift up when nearing maximum revs
#4
Posted 06 November 2012 - 12:41 PM
Ha my arrow is green and yes the Speedo symbol is as haz says when the cruise control is active
#5
Ah I thought it might've been like in the vauxhall corsa (sorry!) I had a few driving lessons in.
Basically told you in ever single gear when to change up.
Probably best I don't start playing around elm and ff2 - I'm a huge geek and would only break something.
#6
Posted 06 November 2012 - 04:10 PM
My arrows green too
they changed it with the facelift model and called it Eco shift up light :S
I think green must use less battery than red
The ff2 software isn't that bad. As long as you use the save function in it to save each page you edit first, then you will always have an original copy to change it back to
Also tagged with one or more of these keywords: Ford Focus, MK2, Zetec, 1.8, Climate, Dash lights
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
Blower Issue! Blows Hot In Foot Well But Only Warm On Window And Full On Blower. Whyyy?Started by trikidy, 20 May 2013 |
Ford Focus Club →
My Focus Zetec S So Far :-)Started by RyanZetecS, 16 May 2013 |
Ford Focus Club →
The New Whip!Started by Focus-Jonny, 02 May 2013 |
Welcome to Ford Owners Club →
General Ford Discussions →
St170 Engine Rebuild Project...Started by Tigercatkid, 02 May 2013 |
Ford Focus Club →
Ford Focus Zetec S Kit! Help!Started by patrick-1020, 29 Apr 2013 |
