trailer sway ye or na
Firstly I will say so for the this post. the reason I ask ii need confirmation that if you fit a towbar with ford dedicated wiring loom and module and it has been programmed in 1.if connected to the caravan I will get a visual on display showing something or be able to go into driver convenience and see something like trailer sway on/off the same as traction control on/off ? my car is kuga mk2 65 plate with sync1 with no reverse sensors/camera.The reason for the question I have just got my car back from major service and the tec said " I don't think it has been programmed correctly and their is no wire connected to the cambus under the drivers side? it was fitted by a NTTA fitting company so it must be right yes or no
Thanks for looking  any advice/ideas before I speak to the fitter
