Car speakers
Hi
looking at changing my door speakers in my mk2 focus
anyone know what size I need please
First car and don’t really have much help around me
thanks
Nicola
@Nrose1113 unfortunately you have a slight problem with a simple straightforward swap this is what someone with the same idea came across....
I've just had the door panels off my 56 plate (Feb 2007) Focus 1.6 Tdi Zetec Estate and can confirm the the speakers are round and match the Haynes Manual. Attached are some pictures.
The front speakers seems bigger than the rear and both are held in molded standoffs that are rivetted to the door panel. Without the standoffs the speaker magnets would probably clash with the window machanism when down as well as being set well back from the speaker grill on the door trim.
The 5"x7" speakers I bought to replace the standard ones are going to be sent back as there is no way I can make them fit without some custom molded standoffs
23 hours ago, Nrose1113 said:
Hi
thanks
Nicola
There 6.5" component speakers,
You will need some aftermarket speaker Adaptor's from ebay.
They fit the ford shape and provide a 6.5" space for the aftermarket speakers.
There's different Adaptor's for the rear doors but there also 6.5"
Front adaptors:
IMG_20150127_075543_zpsc6fy9tpz_edit_1422347743383_zpszrlozox6.thumb.jpg.1ae647d1db848a5f703f942420e4f139.jpg
IMG_20150327_180657_zpstaaxckns_edit_1524854136366.thumb.jpg.98b9b09b5da05edf5e7586f6e7f48b59.jpg
Rear Adaptors:
IMG_20150127_075717_zpsaleb3jks_edit_1422346083114_zpsw1zr8vlv.thumb.jpg.e47a9e0b4459e6238cd63bf67220da59.jpg
IMG_20150327_131635_zpsaeljzl52_edit_1524853886836.thumb.jpg.8552cc3d5ea92805e5a1cf84dd932bec.jpg
IMG_20150327_180704_zpsd7epex1y_edit_1470089710076_zpsigakwk5h.jpg.7d4de977128c376be4a1a6bf04cc2c9b.jpg
I've changed all of mine to JL Audio C3 650
I also recommend fitting DEi Boom speaker baffles for optimum results in the new speakers they also prevent door rattle when the bass is high.
Thank you both very much 😁
No problem,
