Door handle replacement
Hello
I am looking at changing the door handles on my mk2.5 focus has anyone done this and how is it done?
Thanks in advance
I've done this on my Mk2 when I've re-wrapped the door handles.
There's a little grommet on the end of the door next to the door handle. Pull this off and then you need to undo a bolt that's quite deep inside the hole it reveals (I think it's a Torx 20). Keep loosening this until you can pull the trim at the rear of the handle out from the door (the bit which has the lock cylinder on the driver's door and is just a blank on the rest), the handle will then slide backwards and off of the door. Not a difficult job but it can be a bit fiddly working through the hole.
Thanks Dan
Ill give it a go tomorrow just need to change over the lock barrel as well as changing handles for a set of gloss black ones.
Just hope it will look ok once completed
Thanks Dan
Car looking awesome Daz.
Yunii
Sent from my SM-G925F using Tapatalk
Thanks mate
fitted the door handles and now st black headlining as well
Looking good!
The ST headlining makes such a difference, it's much classier.
Sent from my D5503 using Tapatalk
