Ford S-Max Roof Bar Spares - 1724850
Hey,
Does anyone know where I could get replacements for the plastic inserts that sit in the fixing points while the roofs bars are fitted? It's for a 2009 S-Max with a solid roof and fixing points (Roof Bars are part number 1724850 (image attached).
Thanks!
Tim
  • 3 years later...
Did you find these? I'm also looking - and for the bolts. I bought a used S-Max roof bar set and the bolts aren't original.
My Focus MK2 bolts and covers seem to fit, but I want to sell the roof bar with those - covers not quite the same colour.
  • 4 weeks later...
I assume they are available from a Ford dealer ?
  • 2 months later...
Hi
Did anyone find a solution to these? I'm also struggling to find the actual part number for the roof.
Thanks in advance for any help.
Hi Tim, I fund a set on e-bay for 50 pounds. Which is ridiculous. I found this on Aliexpress: https://nl.aliexpress.com/item/1005002586944860.html?spm=a2g0s.9042311.0.0.73d84c4dlivHdU
It came quite fast (in 2 weeks).  The size is the same, but it does not fit 100%. But with a hot screwdriver, I managed to make it fit. The form is also a bit different; the original has kind of 'bow', the AliExpress is 100% straight. However, for 10 EUR (I'm from The Netherlands) still a bargain and it works like the original 🙂
1 hour ago, colonelwai said:
Hi Tim,
Hi @colonelwai - Tim is what we call a "One Post Wonder" he joined 8th May 2018, made one post asking for help, called back 11th May 2018 and has never been back since.
Others may find your post of use, so thank you for sharing that information.
This is great. I wish I had seen this before ordering on Ebay. I found them for £10.99 each which is insanely expensive, but I can confirm they do fit perfectly. If you look closely at the link below the part numbers are there for all 4 as they each have an individual part no. explained by the curved shape I assume.
I've recently bought the car and intend on keeping it for a while with lots of roof rack use so hopefully I can get over the difference in price eventually.... 🙂
Genuine Ford S-Max Galaxy Front N/S Roof Drip Rail Finish Moulding 06-15 1381579 | eBay
