8M5T-19C112-AT stereo or mono cable?
I have a Sony DAB head unit with two Fakra antenna connectors and a 8M5T-19C112-AT  USB BT and Voice module.
I had a good look and there is no connector block or cabling to plug into the BT module.  Having searched various forums and half got my head round what I need to do, I have a question about the retrofit looms to do stuff the easy way.
F1667645  is a 2008 to 2011 Focus mk 2.5 retrofit loom for the module I have, but they are now £230 incl VAT when everyone says they were expensive at £130.  Is this full monty everything you need including USB media streaming, voice control etc. and at a big discount worth buying over any others?
F1467152 is much the same but for a C Max drawing says 2007 to 2010 (but the parts system says Focus 2005 to 2008) it too is £230 incl VAT.... but I don't get what's different, could this just be for the bigger body shell or ?
F1429813 is for a Fiesta 2001 to 2008 and Fusion 2001 to 2012 this is only £98 incl VAT and multiple forums suggest it does the same stuff but for half the price.   However I suspect this is a basic loom to get BT phone only to cars which are missing the wires.  So is this a mono loom.  And a good starter for what I need  but I'd need to fix up the missing 4 pins to get a stereo signal back for the media streaming / USB audio.
anyone have any precise info on these looms ?
anyone have any info on F1429813  -  ford parts ref 14334  -  Jumper Wiring  -  unit price £80.43   ???
found a post here which seems to point to the need for the pricier cable.......
I was also reading a mondeo forum where they went on about earlier 20 pin and later 22 pin plugs
shame there's less info about  F1429813  -  ford parts ref 14334  -  Jumper Wiring  -  unit price £80.43   ???
JW1982    1,083
  • Ford Enthusiast
  • JW1982
I suppose you mean Finis number 1467152. Finis number 1467152 is definitely the cable of the old Bluetooth/Voicecontrol system. This cable is used for the Focus MK2 and very early MK2.5 models.
The retrofit cable of the newer Bluetooth/Voicecontrol system should be Finis 1667645. The Ford dealer should be able to confirm this.
If possible return the cable to the Ford dealer and order the correct one. If your current cable can not be returned it is possible to rewire the cable.
