P0087 & P1180
I have a 2008 1.6tdci and have had the engine malfunction warning coming on i have found out he fault codes are P0087 and P1180 Powertrain faults.
I have had the fuel filter and the fuel rail sensor changed and am still getting the problem. Would appreciate any advice in what to do next
Fuel pressure regulator maybe?  Have you watched the fuel pressure on live diagnostics at all?
  • 5 years later...
Was there a solution for this? I have the same problem.
2008 Focus?  Have you had all the obd codes read? Any (U) codes like u1900?
may be can bus issues if so. ( instrument cluster solder joints or gem module connections)
worth checking
