Starting issues
So far I've replaced the battery, spark plugs and what I was told was called the air flow filter but others disagree on the name of the part. There's nothing coming up on diagnostics. I don't want to keep throwing money at it but no-one can seem to pin point what the problem is.
It could be a number of things, but it would help if you went into detail a little more. Like does it try to start? Does it start and then die straight away? Or run for a few moments with a rough idle and then stop ticking over?
