Impressive MK8 1.0 EcoBoost 140 MPG
I do a 60 mile round trip to work ,25 miles dual carriageway and m25. Sticking religiously to 60 and not rush hour times but really early morning . Using bp at the moment. And using eco mode totally dulls the accelerator but helps for mpg runs
Edited by Stlinesteve1981
On 7/4/2018 at 2:03 PM, Findlay said:
Don't think it is wind direction as every time it has been dead calm - sunshine all the way and no wind turbines turning en route. I think it has to be a fuel issue - wonder if anyone else has noticed it with Applegreen?  They seem to have taken over a few BP stations lately on the A1.
5mph head or tail will make a difference at motorway speed. The engine consumes by mass flow, but the consumer measures by volume flow. Fuel is permitted to have a +-4% variation in SG and the fuel at the two ends of your trip might come from different refineries/depots.
I have long been a "this fuel is better than that fuel" doubter. Some time ago with a change of car, I thought Asda and BP gave different results. The only reason I could come up with is that the two main forecourts I was using have a slightly different slope so there was a difference in air space when brimmed. Over the longer term the difference smoothed out, as expected.
With normal petrol but using speed limit I’m getting almost 600 miles to a full tank
Is this the 140? Are you using cruise control? What's your driving style? What's the max speed you drive? Eco mode?
Can you report back after you've done, say 300 miles on that tank to tell us what the mpg is.
Only asking because I switched to Super Unleaded for my previous fill up, did a 70 mile evening trip, mixed roads, mainly 40-60mph and after that trip, mine reported as 54.7 mpg (Fiesta Vignale 140bhp)
When I filled up again after about 2 weeks (normal day to day driving, work, low miles, a few 20-30 mile trips, using active cruise control a lot, and no eco mode) my mpg was back 'down' to around 42.5mpg (working out by litres dispensed/trip meter mileage) and car said 43.2 mpg, this was after around 355 miles.
That is quite impressive for a higher BHP engine and is actually about the same as I got in a (finished today) drive through parts of Western Germany. For the 600KM ride there and back it averaged 5.3l per 100KM or 53.3MPG. Certainly among the better results I have had but not quite as promised. When doing my usual commute the efficiency dropped by about 20% on average compared to that.
I find that if you fill up and reset the trip data, it can very easily report an unrealistically high mpg for the first 200 miles, it then nose-dives to unrealistically low reported mpg for about 100miles, before suddenly flipping back to a realistic midpoint which is usually a couple of mpg above the real value I am calculating at fill-up.
In eco mode on long steady trips it will often report up to 60mpg at the start, but I've never got above a calculated 52mpg. Typically it's about 48mpg in eco.
I have started using the speed limiter now and set to 60 on dual carriage way and set to 30 in town , always use eco mode and not driving in rush hour . I do 64 miles a day and barely any town driving. I have done 1700 miles and I’m on my 4th tank. I reset figures every fill up and when u work out miles travelled to what’s left it’s always over 500 miles.
I've noticed a strange thing happen with the MPG on my ST-Line X 140. According to the trip I get around 53 MPG from full to about half tank, then all of a sudden it will drop to low 40's until the tank reaches about 1/4 full, then it returns to around 53.
This repeats with every tank full, doing the same journey every day.
See my post above. Mine does it regular as clockwork from a trip reset - at 235 miles driven the mpg drops off a cliff, then at 280 miles driven instantly goes back up about 8mpg.
  • 3 months later...
Interesting to see it's not just me - I was really disappointed with MPG dropping to mid 30's but time the time I get to the refuel prompt it's sorted itself out
